makermodeon25
Member
- Joined
- Jun 25, 2025
- Messages
- 5
I'm having a tough time getting flexible snap-fit joints to print right on my Ender 3. Has anyone figured this out? Any advice on Cura settings or other tips to get better prints would be great.
Flexible snap fits on an Ender 3 are tough, but doable! here's what you can do:I'm having a tough time getting flexible snap-fit joints to print right on my Ender 3. Has anyone figured this out? Any advice on Cura settings or other tips to get better prints would be great.
this setting is perfect for flexible filaments like TPU, but OP might need to push them further. In Cura, make sure your flow rate is dialed in, TPU can be a bit finicky and often needs to be bumped up to 105-110% to prevent under extrusion.Flexible snap fits on an Ender 3 are tough, but doable! here's what you can do:
Slow speed (20-30 mm/s) is key.
Minimal/no retraction.
Higher nozzle temp.
Check your extruder for gaps where the filament can buckle (all-metal helps!).
Good first layer squish on a clean bed.
