Model Mismatch Error
Eric1001
Well-known member
Jul 14, 2025
52
When I try to do a remote print, I am getting a " Model Mismatch, unable to initiate printing error. Does anyone know what is causing this error? I do not know why this remote print fails when it has been working just fine, without any errors or problems.
So I downloaded the g-code to a USB drive and printed the model without any problems (other than the first layer being a mess not sticking to the bed). Also Workbench shows it is communicating with the printer (Kobra 3 Max).
I spoke too soon. It is not printing in the center of the bed, but on the left side of the bed.
I have reset the printer's settings without any luck.:cry::cry:
Sounds like the slicer and printer are out of sync, not a mechanical problem. Remote printing tends to mess with the origin data sometimes. Export your G-code to USB again and if it prints centered that way, it’s 100% a slicer profile or Workbench bug, not the printer itself.
I do not know if it was repair elves visited me last night or what happened, but it is working perfectly
hmmmm interesting that sounds like something briefly glitched between the slicer and printer handshake. Sometimes the remote print cache can cause mismatches if the g-code metadata changes after slicing. Did you happen to update your slicer or the printer’s firmware before the issue showed up? Might be worth comparing notes if others have seen the same behavior recently. Did it happen again?
