I had a long print last weekend that was looking perfect for the first hour, then it started doing that sad thing where the lines get skinny and the extruder starts sounding a little more clicky. I paused it, panicked a bit, and I honestly could not tell if I was dealing with a clog starting or heat creep slowly choking the filament. I ended up canceling because I did not want to cook the hotend for nothing.
When this happens to you, what is your quick mental checklist to tell the difference fast? Like do you check if the heat sink fan is actually spinning, try a cold pull, bump temp up a few degrees, back off retraction, or feel if the filament is getting chewed flat by the gear. I want a simple order of checks so I stop guessing and wasting half a spool every time it fades mid print.
